Mugabetown - Whoretownin' At It's Worst.
Who has z32's afm's and how on earth did you attach air filtering equipment to them? there seems to be literally no info about how to go about it.
what filter did you get? The filter must be adaptable to 80mm AF meters or else it will never fit!
Still in the office bro.. :(
mate dafaq goin on?
Gettin up early to goto work, stayin late?????
Ask yourself this..............will all my time and effort be rewarded if so...........in what form?
Do not answer that question Tony. Just think about it.
None yet. Don't really want to just bolt a filter onto it sucking in hot air though... but its the last ditch option.
I don't think anyone sells elbows that go on the end to move the pods over a bit in the z32 size, or adapter plates. That being said, adapter plates wouldn't actually be that hard to make
The other option is buying a stock airbox, enlarging the holes 15mm and drilling new bolt holes for the AFM's, as they're in stock location they'll still be flush against the airbox (might be issue with flange protruding past the edges of the airbox face though).
Or i could just buy cheap china spec hard pipe+z32 mounting kit for 300 bucks
mate dafaq goin on?
Thanks for the concern mate. There's actually been a lot going on behind the scenes. Few know. Even fewer understand. Just tried calling and then realised the time. Sorry mate!
Anything that bolts to an RB25DET AFM should also bolt to a Z32 one I think you'll find
all good mate. I was just falling asleep as I could here the phone.
Il call you to catch up.
And morning all
  • Like 1
Morning mate. Really dislike hay fever but that's just a minor inconvenience. Today is going to be a very good day.
thats the way. Got a text message from one of my new clients 10mins ago.......my day will again be interesting to say the least.
Love great starts to the day. Sets everything else in motion.
Last week, had to text a candidate at 5:45 because I had an offer for her. Also messaged another girl at the same time with some other awesome news. Good news = good start to morning = good day.
A custom air box with a neat cold air induction goes a long way I think Pete
exactly why I don't want to just bolt up to the afms directly.
in any case,I think I'm just going to have to wait till I get home to figure out what I'm going to do with them
And nope not me on stage with Taylor, I wouldn't say he was lucky as she now thinks he's a pysco. I'd rather be up there as her lead guitarist :/
them drugs Nick................what I tell you bout them drugs!
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
