Mugabetown - Whoretownin' At It's Worst.
You're*
Also thinking about starting a DS circuit and coffee thread to throw pictures/things I find interesting at the events into
Silly gat-ton, no one cares for cars with hectic poke/thrush and 5 packet of zip ties used to hold the rusty POS together.
  • Like 1
Didn't Scott buy them
Yeah he bought the massive ones...
Have another set of r34 gtt front calipers (310mm rotors etc) and z32 rear calipers...
Also another set of z32 fronts and rears...
.... I care to an extent, not my thing but I think it has it's place in the car scene. I'm happy to sit back and watch them get defected with there natro ca18 as I roll on by with my 160mm of clearance lol
The question is more around why you would post DS events and pics here? They're essentially competing with us for events etc and you want to assist them by promoting their shit?
I wanted you to help us with the drag day, but if this is demonstrating your thoughts on this matter, then we'll find someone else.
Seems a tad aggressive.
