Mugabetown - Whoretownin' At It's Worst.
Also what kind of f**ktard brings this kinda crap for completing their annual income tax returns?!
That's twice as neat as mine! :P
Ol matey has many receipts that are faded - guess what??? it's deductions he could of had but we don't even bother!
Are photocopies are valid record? Seems to be the only way to make a receipt last!
any evidendence helps but does not mean it will be valid.
Unless you pay cash for EVERYTHING you acquire, theses days you can rely on other documentation to support your claims................also if you do pay everything in cash that will most likely warrant further investigation :woot:
you should know by now the receipts fade away.........so you can no longer rely on such records for substantiation
Thought that you can have receipts photocopied with the original attached or scanned into the acoflamin mongreling package and that would suffice.
Also know of a firm on the northside where the Partner has a box of receipts worth about $20k that he uses for all his clients... Legit as bro.
If I end up in the kitty litter at turn 1 I know I've done it wrong lol. Driven it s few times in last two days and they seem fine.
I must admit I tend to just stare at their awesomeness whilst its parked in the garage
  • Like 1
You can photocopy whatever you want mate.............at the end of the day it will all come down to the integrity of the individual / business being reviewed....................they will profile you based upon the information you furnish to them and that will give them lead indicators on what is credible and what is not.
CSI is baiscally coming to reality guys.
sexy brakes are sexy to look at Scottie ;)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
