Mugabetown - Whoretownin' At It's Worst.
Dude 170mph terminals that's a low 8 any day if the week
joys of no traction....Shows what happens when you have too much HP. Colin in his R32 GTR has like 900 odd with a 2 speed and runs mid 8's with <155mph
This has 1300~
And Scott the joys of no traction are having no traction der
This has 1300~
I am aware of the power that 101 Motorsport car makes lol...
No traction isnt joyous when you are trying to keep it.... Mind you no traction does get the bitches I've heard
car is tuned with std Afm's and injectors. Put in Z32 afm's and 850cc injectors, what's going to happen? Cancel the effect out or is the ECU going to have a fit? Car needs to get from Mt Gravatt to Southport, that's all.
What !? Yes it should
I turn tire over 100 now, roll first punch it at 60 bang second hold flat to 115~
i was kidding.
from memory i did it in front of you going to downshift last month when the a bomb was behind
I don't think it would run. The AFM signal being the main culprit.
That's what i'm afraid of.
anyone know any good trailer rental mobs?
Alternatively i could shell out for the nistune software+cable and fiddle with the ECU to get it working i suppose
i was kidding.
Sarcasm do not translate well much not over interwebs forum text
And yes you did, with semis on lol...
In other forums I am on you have to do sarcasm in green font so people know you are doing sarcasm!
Semis bake easy on the street, they never have enough temp in them!
Needs more MAF lEss tune and over the radiator lol
Scarnon buntcake
Not much man, just enjoying being in my own house!
It gave me a semi...
I'd be surprised if they weren't up to temp as we always have a very spirited drive out there. And tee up a fair few races
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
