Mugabetown - Whoretownin' At It's Worst.
Dude 170mph terminals that's a low 8 any day if the week
joys of no traction....Shows what happens when you have too much HP. Colin in his R32 GTR has like 900 odd with a 2 speed and runs mid 8's with <155mph
This has 1300~
And Scott the joys of no traction are having no traction der
This has 1300~
I am aware of the power that 101 Motorsport car makes lol...
No traction isnt joyous when you are trying to keep it.... Mind you no traction does get the bitches I've heard
car is tuned with std Afm's and injectors. Put in Z32 afm's and 850cc injectors, what's going to happen? Cancel the effect out or is the ECU going to have a fit? Car needs to get from Mt Gravatt to Southport, that's all.
What !? Yes it should
I turn tire over 100 now, roll first punch it at 60 bang second hold flat to 115~
i was kidding.
from memory i did it in front of you going to downshift last month when the a bomb was behind
I don't think it would run. The AFM signal being the main culprit.
That's what i'm afraid of.
anyone know any good trailer rental mobs?
Alternatively i could shell out for the nistune software+cable and fiddle with the ECU to get it working i suppose
i was kidding.
Sarcasm do not translate well much not over interwebs forum text
And yes you did, with semis on lol...
In other forums I am on you have to do sarcasm in green font so people know you are doing sarcasm!
Semis bake easy on the street, they never have enough temp in them!
Needs more MAF lEss tune and over the radiator lol
Scarnon buntcake
Not much man, just enjoying being in my own house!
It gave me a semi...
I'd be surprised if they weren't up to temp as we always have a very spirited drive out there. And tee up a fair few races
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
