Mugabetown - Whoretownin' At It's Worst.
Located in Wishart Mike.
Fuel injectors haven't arrived, and i'm about to go back to site, so the 6th of march is The day that they and the AFM's are going in, I get back on the 5th and car is booked in on the 7th. Shouldn't be to hard to knock over in the day though. The software seems fine in Trial mode, it isn't cut down at all, just limited to 10 minutes per use. If I could borrow a cord though, that'd save 100 bucks...
Latest musing on my car related shenanigans:
  • Buy consult cable, (this would work, right?)
  • install free Nistune trial software,
  • adjust injector CC and AFM to match,
  • drive car to EFI
  • Profit
Sound like a plan?
That's all I did when I did mine. Just don't go nuts on the way there before the tune.
I'm astonished at the level of risk your taking just to save a few hundred dollars.
Sean will have to recheck EVERYTHING you will have done and in the event something is not right he will have to fix it.
Yes he can easy install AFM and especially injectors, including fuel pump, ECU etc......
Didn't know that, have not been there apart from dyno day (where i was sick as a dog) since ERD closed down.
As far as the ECU goes, i'm talking about changing injector sizes and AFM's. Its a case of putting old and new CC and it scales the map, and selecting Z32 from a drop down list. Not actually messing with any of the ignition/fuel maps etc.
its all at your discretion Pete. All I know is that it's a long way for you to drive the GTR to EFI and if something goes wrong in between..........well it's just a long way
If the nistune scales the map for you, you should not have any problem
I think a long drive is overdue then. Then retune and bring to next happy laps :-)
i agree but bits of car are being reprinted FTM.......plus I'm very busy at work so limited time.
Yes, a full tune with E85 is on the cards ;)
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
