Mugabetown - Whoretownin' At It's Worst.
Located in Wishart Mike.
Fuel injectors haven't arrived, and i'm about to go back to site, so the 6th of march is The day that they and the AFM's are going in, I get back on the 5th and car is booked in on the 7th. Shouldn't be to hard to knock over in the day though. The software seems fine in Trial mode, it isn't cut down at all, just limited to 10 minutes per use. If I could borrow a cord though, that'd save 100 bucks...
Latest musing on my car related shenanigans:
  • Buy consult cable, (this would work, right?)
  • install free Nistune trial software,
  • adjust injector CC and AFM to match,
  • drive car to EFI
  • Profit
Sound like a plan?
That's all I did when I did mine. Just don't go nuts on the way there before the tune.
I'm astonished at the level of risk your taking just to save a few hundred dollars.
Sean will have to recheck EVERYTHING you will have done and in the event something is not right he will have to fix it.
Yes he can easy install AFM and especially injectors, including fuel pump, ECU etc......
Didn't know that, have not been there apart from dyno day (where i was sick as a dog) since ERD closed down.
As far as the ECU goes, i'm talking about changing injector sizes and AFM's. Its a case of putting old and new CC and it scales the map, and selecting Z32 from a drop down list. Not actually messing with any of the ignition/fuel maps etc.
its all at your discretion Pete. All I know is that it's a long way for you to drive the GTR to EFI and if something goes wrong in between..........well it's just a long way
If the nistune scales the map for you, you should not have any problem
I think a long drive is overdue then. Then retune and bring to next happy laps :-)
i agree but bits of car are being reprinted FTM.......plus I'm very busy at work so limited time.
Yes, a full tune with E85 is on the cards ;)
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
    • Nice, that's not laggy swtching between functions at all. Could it be less laggy than the factory one below? 😋
    • The 400R sold all 1000 units and 100 of the limited model so I'd say even if they just sold the GT with a manual it'd sell out in Japan for sure. I say 'sell out' because like the 400R I'm certain that Nissan JP will only offer it in limited numbers, or even in 150 unit increments like Toyota did with the GR Corolla (and sold them by lottery which I was denied 2 times, so gave up...)
