Mugabetown - Whoretownin' At It's Worst.
-5 with e85 should get 400kw at the wheels pretty easily. Most of the -5 equipped GTRs I see go through EFI make 370 to 385 on 98 and e85 pisses power by comparison.
Stupid turbo cars making bulk grunt on e85, natro motors don't get a lot.
It's going epically slow......only have the weekends to find a bit of time to work on it.
I ran out of paint as well so that did not help.
Got some more paint last weekend.
Still paint stripping rear bumper but it's getting there.
Once my work deadlines are complete I'm going to take a day off to hopefully get more work done.
Should be good once all finished......we'll it better anyways lol
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
