Mugabetown - Whoretownin' At It's Worst.
Here enjoy some poetry
"So sit down my children
I've a story you see
Of good money squandered
On my r33
'Twas a warm summer evening
I laid eyes on her
It wasn't to angry
The sound of her purr
A sad '25
Lay under it's bonnet
No turbo in sight
I should not of bought it
But big plans lay in store
For the R33
To make it a monster
Powered by LS, not RB
I cut and I hacked
And I swore black and blue
And turned this poor car
Into a thing owned by few
It lives! I cried
As the LS erupted
This car has a soul
A soul I've corrupted
I fear no RB
As I roll down the highway
Stuff the conformists
I did it my way"
On my r33
I laid eyes on her
It wasn't to angry
A sad '25
No turbo in sight
For the R33
I cut and I hacked
It lives! I cried
As the LS erupted
This car has a soul
I fear no RB
I did it my way"
To much time on your hands..
Btw I like brakes
brembos from other cars ie R34 GTR are a poor upgrade...........save and get a big brake kit........I'm not a fan of Chinese brakes hence why I have AP Racing 6 pot brake kit
Brembo F50 / GT kit, Endless, Trust / Alcon all quality brakes but expensive
Mmm, much monies....
Shall have to get saving!
Yeah, money isn't really an issue at the moment, it's just a matter of time saving it. Car isn't going to be tracked seriously though, so I doubt that i'd get value out of a big brake kit. Get the impression that the R34ones are a little overpriced (cause R34, cause brembo), the 33 ones look like the ticket.
Edit: they're the same size anyway, didn't realise that.
edit edit: reading over old threads. 355mm rotor and caliper kit, 2006, $10000 bucks. :O
R33 brembos are not the same size as r32 gtr brakes. 325mm vs 296 R33 ones work easier than r34 ones because the bolts are the correct size.
yeah, I meant 33 vs 34, same rotor size, different caliper mounts, same pads.
for fr and rear yes. just upgrade the fronts to start of with then do the rear IF you need to.
After having a big front brake the rear brakes do not need to work as hard anyways so for occasional track days (even than occasional) rear stock calipers will suffice.
My Front APs cost less than 4,5k IIRC
After having a big front brake the rear brakes do not need to work as hard anyways so for occasional track days (even more than occasional) rear stock calipers will suffice.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
