Mugabetown - Whoretownin' At It's Worst.
How are things on your end? Was reading what you were saying about the systems being down and thought, "who the hell is playing golf in this weather?!"
Quiet with all this rain.
The big frustrating thing about our sytsem is that it runs an electronic tee sheet & our POS system. So if its down you have no idea how busy its going to be, who is playing & what rate they are meant to pay. As we start at 5:30am there is generally no tech support that early either so its frustrating at times
Move to a provider who can provide after/before hours tech support?
Unfortunately the providers we have are actually the biggest in the business, whilst they may not offer the best tech support may not be the best.. There is extra revenue streams they offer that other systems dont etc.
Necessary compromise it appears...
So, I bought a hard pipe kit so I could fit in my z32 afms. And it has no bung for the bov return pipe on the rear turbo, should I just block that line off and run the bov only to the front one?
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
