Mugabetown - Whoretownin' At It's Worst.
*line up the cars for photo* *all crash into each other*?
this
It won't be a time attack Bodo. Me thinks you have skyline fever
bah, skirts :P
Yeah it's happy laps, I won't be going anywhere near fast enough to have issues, I just want to go for a drive with the ant eater!
lol, why do you guys all assume I need to be going far too fast all the time?
Especially with the chicane and a few cars on track, lakeside is safe. having said that, you can still go quite fast without any safety issues and hooking it through the witches hats as fast as possible is fun too
Morning all
Morning...slow morning it is too
Same same powahz as the abomb :)
less than half the displacement and at all 4 wheels I assume? or was it a 2wd dyno?
'As fast as possible' is not somthing I will be aiming at during Happy laps is all I am saying
Installed new Clamps... but don't really want to test them out. Got it up to 9PSI just on back streets around here (within limp home range) so I can drive the car... but i feel like i should get it to a QR happylaps or something to open it up properly, not the motorway where i can't get it off.
also, why the hell did nissan put the BoV's there.
Meh. Just take the necessary tools with you on the test run Pete. No need to wait for QR for that.
I guess i just need to pick a nice illuminated road with plenty of space on the side.. would get my legs run over taking the front bar off on the freeway!
That takes dedication, I'd presume doing around the letters must be a real pain in the ass?
it should be ok. A tooth brush will do the trick.
Not wrong re dedication but I enjoy it.
Got an idea about detailing the 'skyline' letters ;)
Secret for now
Secret for now
Nissan did have a factory option to add a red sticker that sat in the skyline letters on the rear bar. Probably wouldn't look too good on white but looks awesome on the darker colours
yeah seen them......looks like crap IMO
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
