Mugabetown - Whoretownin' At It's Worst.
Brake talk... Bah
Come on Nick. All you got to do is remove the R and you're in heaven
Sneak peek of my new toy
Looks good Mike. Will we be seeing this at happy laps?
Good piece of machinery the Navara. I bought a new D22 a few months back.... Still havent towed anything with it though lol
Defs keen. Have not much camping gear at the moment, but plan to improve that.
Sweet, Anna and I have most of the cooking stuff needed so if you had shelter and an Esky you would be pretty right.
We just need to find a time to get together and choose our 4x4! with Anna working on the Opera at the moment its going to be 3 weeks at least before we can even go test driving!
Keen for camping. We just steal Christine's mums Navara for it. Navara camping party aww yeah
Well we are out then...I don't plan on a Navara at this point! :P
Edited by Bunta
Anna is the one that drives it most and she wants a more car like experience, and fair enough she spends a lot of time in shopping center car parks ect. I wouldnt mind a twin cab but it doesn't meet the brief. In fact just about the only real 4x4 that does is a Grand Vitara. If that's no good to drive I am not sure where that leaves us!
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
