Mugabetown - Whoretownin' At It's Worst.
That many?
New car is fast. Fast car is fast. Nearly scary fast. Will be even faster with bigger injectors and more boosts. Injectors are pretty much maxed out atm.
Edited by MagicMikeZ32
How many kw's are you guys making at 4k rpm?
Out of interest...
no efffffin idea Mike.
-5s on standard 26 are very sluggish and would not be surprised if a Honda Civic goes faster than me at 4Krpm
Out of interest...
Mine was 225kw last time. That was its base tune with the new ecu still limited to 4k, hoping to get a lot more when i can run some timing and boost
What turbos Bunta?
Makes for a fast streeter making that much so 'low' in the rev range...
HKS 2510s with a few select twists courtesy of MTQ, and yeah its pretty much perfect for street duties.
Edited by Bunta
*WOW* great numbers that is @ 4k rpm
Yep, pretty happy with it, will see what the final result is in the end.
2510's are pretty small...
What kind of peak numbers are you looking for?
yeah they are small, as for peak figures I couldn't really care less, I just want a huge midrange, peak figure so far is 306rwkw at 14psi with very little timing, given the 'bastardised' nature of the turbos I have no idea what they are capable of.
I understand why the need for a stroker would suit you.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
