Mugabetown - Whoretownin' At It's Worst.
VH45? Great low and mid range. Whack a turbo on to it for top range and all the scissor throwing at dirty LS1....
Get one out there that's a natro, happily walk it's sorry Nissan ass up and down qr all day ;)
Why would I do that when I could buy a spool kit, whack 2530s on it, still look stock, and punch out 400kw with wicked response!?
I now know fur a fact that he dosent :P
Would like to know what yours does make at 4k though, out if interest.
Prev owner has owned the zed for 15 years :) And went through ALOT of various setups. First dyno sheet on the pile was in safety boost. Last one is gtx2863's.
and what are you going to do to it Mike?
Get it QLD rego first lol
Then plans are, hopefully manage to get engineer approval to run flares and big fuark off wheels.
Then, once I am more used to the power and want more, get some bigger injectors and install my twin 2.5in intake and IC pipes (to and from turbos), and some more boost.
Then, maybe, just maybe the widebody will be closer to being finished the design and mould phase. Then a possible color change along with widebody ;)
Oh and I will be removing the retrimmed interior panels from my red zed and swapping the tweed out of the new one :)
Edited by MagicMikeZ32
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
