Mugabetown - Whoretownin' At It's Worst.
Speaking of tax dollars, repeal day was yesterday. What are Mr Ants' thoughts on the matter?
About bloody time!
I welcome these amendments in fact I could almost kiss them.
We live in a really wonderful country that offers incredible opportunities to the ones that are searching for it compared to other well developed countries. HOWEVER, the level of bureaucracy in Australia has been on the rise for quite a number of years and not only is it burdensome to us all but has prohibited Australia to become more competitive as well.
Removal of the so called ‘red tape’ is certainly a welcoming measure and will assist businesses carrying on what they do best and that is concentrating on their business operations.
Australia is simply too highly regulated and having the need to have a watchdog for every sector is simply not viable and canning the watchdog for charities is fine by me especially since the ATO has been already been administering these duties already.
The reduction of compliance requirement within the future of financial advice act (FOFA) is a doubled edge sword though……….I know many financial advisers that do the right thing by their clients and do not even accept commissions and as such would benefit from yesterdays reduced regulation, HOWEVER, it is other gung-ho financial advisers that need such regulations in place to keep them in check. I think that other controls should be put introduced like maybe force each financial advisers (of certain size) to establish a risk committee within their organisation to mitigate any potential abuse or self-interest arising and reports from the committee can then be audited / reviewed by ASIC (just an suggestion I thought of as a middle ground)
This is only scratching the surface, more unnecessary regulations need to be removed at Federal level and especially at State government level; take a look at your local councils for example, you need a form for a form to get another form these days, thus only adding to the frustration of us general household consumers to try and do the right thing i.e. could be getting soil testing done, permits, etc….
Much more to be done but this is a good start.
About bloody time!
There's definitely a lot more that needs to be done but it's a great start. The number of people working in government in antiquated divisions is remarkable...
The filter in the RB, while not difficult, could be a lot easier. Magic Mike wins that round
Ls1 oil filter, directly at the bottom with nothing in the way and you don't end up with oil on your block
I hate spark plugs on any rb with a crossover pipe. Again not difficult but well annoying
Spark plugs on an ls1, open bonnet take of lead unscrew put in new plug put on lead close bonnet
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
