Mugabetown - Whoretownin' At It's Worst.
Rb26 oil filter change has defeated me. How the f**k do you get the f**ker out. I think i may need a smaller tool to get to it.
It also feels like the filter on there is smaller than the replacement Z145a one i've got, but that could just be tiredness creeping in
You forgot: buy oil filter relocation kit as the step before that i think. Will be putting one of those in next time.
yes mate get one.
The way the standard oil filter is mounted on the side of the block is beyond f**king stupid
On a random tangent, I'd love to have a rally prepped WRX or EVO out on some of the tracks in the gas fields right about now...
Without in vehicle monitoring equipment of course. I wouldn't be wanting to drive them at 40km/h....
My sister and brother in law are getting rain on the farm up at Biloeila too, should be enough to get them through winter, they still needed to sell a lot of stock at no profit though. But at least the breeders they kept should now make it through.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
