Mugabetown - Whoretownin' At It's Worst.
Haha. I get a mild case of OCD too if i have a desk etc... Weird.
My love of silence got that extreme that i used to work with a friend that sat at the desk next to me. Not Barrier or anything blocking our view at each other, however it got to a point where we would email each other in coversation instead of looking a meter to the side and actually asking lol
I don't mind a bit of banter around the office and background noise helps. in our industry, it's meant to be loud with people on the phones etc however when it's mindless BS because our junior can't remember what she had for lunch the previous day let alone where a candidate is currently working, pisses me off.
Eg: Yesterday, the boss came in and we were running a brainstorming sesh for this new campaign. He was asking all of us about candidates that we're working with. I could tell you where they worked, how long for and where they lived without looking. The other senior consultant was close. Our junior couldn't even remember surnames accurately! WTF?!!? So when she asks me the same question 3x in a day, I crack the shits.
You really were born in England weren't you? :P
  • Like 1
Back in Bris. Got home just before midnight last night. Plane from Mt Isa was late leaving, but I upgraded to business class, assuming that we would be doing laps of Bris with all the rain.
Chivas ftw, didn't care how late the plane was haha
Also, have all paperwork with me to go get some shiny new rego plates today!
Agree, Mindless conversation is annoying. Also another thing that grinds me is unnecessarily loud phone voices in an office.
Just unnecessarily loud voices In General Scott haha like people that have to talk rediculously loud when they are right next to you, fair enough when there is a lot of background noise and you are gonna struggle to hear but when there isn't and they are like yelling.
we have one of those, he also puts his phone on speaker so its double loud voice! Last week I had on noise cancelling bud type ear phones and proper industrial noice cancelling ear muffs and I could still hear him when there was a break in the music
He's calling you a pom bloody smash 'im
He gets it
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
