Mugabetown - Whoretownin' At It's Worst.
In other news... Swapped some 2871's into a mates zed over the weekend. What a PITA.
Goes pretty decent tho, considering 14psi and a stock engine with low comp on at least 1 cyl :D
I found them quite good also :s
For the price
They're decent in the dry, but absolute rubbish in the wet. As quite a few at the sprint day last year will attest to :P.
If you think they're 'quite good' in the wet, you need to try some other tyres ;)
Ohhhhhhh I didn't realise they were designed to be a wet track tyre! :P
Kuhmos FTW!
For real though 595s are never going to be excellent in the wet, they have no radial grooves, The EVO or the RPM are needed for that. Trouble with either of those is the crappy size selection though, Luckily I can fit a 285 if I really must.
Edited by Bunta
I wasn't using them at the track... but others were and found them to be quite useless.
I have used them on the road before though and they were terrible in the wet. This pair I just found in my garage, I think I bought them second hand from Pete. They are equally awful.
You are right they are never going to be good in the wet due to their tread pattern. Just can't figure out why people keep buying them and claiming they are god's gift of cheap tyres when they are so, so bad in the wet :S.
Guess the kiddies just love their liquid horsepower and don't know how much better it is to have tyres that actually provide some traction in the wet
You are right they are never going to be good in the wet due to their tread pattern. Just can't figure out why people keep buying them and claiming they are rajab's gift of cheap tyres when they are so, so bad in the wet :S.
They get most of thier props from the drift community dont they? and for that they are especially good, can take a real beating
Because it almost never rains?
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
