Mugabetown - Whoretownin' At It's Worst.
It does sound like wrongful impoundment. Whilst fighting it will still result in the car physically being impounded for those seven days, your mates be eligible for a suspended sentence and thus a little more leniancy next time.
As I said, the phisical impoundment isn't that much of an issue it's the first impoundment offence I'd want removed.
Isnt the first type 1 offense not an impoundment? And I spent a few hours reading over the legislation when it came out and I am fairly certain that things like low and loud are not on the list of things that can get you impounded unless they are in the context of somthing like racing, burnouts ect. I would be contesting it too, sounds like a case of police throwing shit and seeing what will stick.
Pretty sure it's the other way around Bunts. First Type 1 is 30 days impoundment and first Type 2 is 7 days impoundment. Let me get googling.
So, if they were all on their second defect then that would make sense... Nothing to do with the line
Seems that way, although they may have used that as the excuse to pull them over.
Well by that definition they were too low so they get done for a type 2.
It does Mike.
However, the problem I see here is that none of us here except for Kiwiphil were present and cannot make a full conclusion unless you have all the necessary facts.
It is possible the cop stuffed up
It is possible that the cop didn't stuff up
I have question though......
Say the police officer was in the wrong and you wanted to fight the offense / infringement
What would be the procedure and would this involve the requirement to be represented by a lawyer / legal representative and associated costs?
I wish I could find the info I mined last year on all of this, Tony was right, I got them backwards I always do. There was something in the "prescribed sections" that made it really not as bad as it sounds. You have to did through 3 separate pieces of legislation but eventually you get all the info you need.
Seems strange that all of the people pulled over would have been on their second offense
It does Mike.
I believe you have to request a court hearing and then bear all the associated costs. If you show the cop made a mistake you may get costs awarded to you but then again you may not.
So again it comes down a commercial decision doesn't it?
Costs vs benefits
I will most likely make a visit this week to my friendly QMR dept for the Ant-Eater.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
