Mugabetown - Whoretownin' At It's Worst.
twas indeed, looked good. Got dark real suddenly yesterday arvo
Ive decided to trailer my car to the EFI tomorrow to avoid the chances of the po po pulling me over during the Easter Break....
Also contemplating getting rid of the plazmaman plenum in favour of something that sits a little lower
mostly highway to EFI, you'll be right :) just watch that right foot....they get heavy after driving for a while.
What do you want for it?
$875? lol
Not something i want to risk at the moment. with car events being so close. Knowing my luck there will be a HWY Patrol car lurking
What do you need it in the workshop for?
Tune. Long story short, Half moon indicator on cam snapped, not exactly sure if I got the CAS on in the exact position in should. Went to dyno day. They reckon it was leaning out up top. Ive also had a bigger exhaust put on last week.
Think its best if I get it on the rollers, even if its just to make sure everything is ok. If we can squeeze a little more out of it then its a plus. I wont care even if it makes the same power. I'l just be happy that i know its all running right
lets see.....,bigger exhaust, corrected / optimized tune....,was making 588hp on prior tune......you will def make more poawa bro
I agree Ants. My only goal though it to make sure its running good for Powerplay. Oh and i guess getting a dyno sheet of me breaking into the 600's would be cool
You are a smart man Scotty, I don't care what everyone else says, I rekon you're alright :D haha
Haha I dont believe you for a second. I've seen the shifty eyes you throw around. I need to see your Zed collection one day
when you coming down tomorrow Scot?
Spending more time on the skyline this arvo
Plenty of pics will be uploaded tonight
Already have people lining up for bits from the old one
Gotta love having people lined up for parts before they are available
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
