Mugabetown - Whoretownin' At It's Worst.
$450 and a broken snes controller?
Got any fish tanks? Sounds good bud. I'm at mum n dads this weekend so I'll pick it up. Could meet you somewhere on the weekend if you can?
Not back in Brisbane for 14 days and country unfortunately, just got to site.
The engine has a R34 sized oil filter on it, would that be an issue or are they all pretty universal?
Not sure should be the same I would think. Not a lot changes between models
Just a 34 filter. (genuine Nissan item even!). I can always check it by holding a 145 next to a 442 in supercheap when i get back i suppose, but it should be good.
I'm assuming if the 442 fits on the 32 at the block its the same seal between each block at least so the sandwich plate should be the same
Yeah that's the same assumption i'm working under.
You still goign to be around in 2 weeks? Or over in india or something?
Nah ill still be here unfortunately lol. Indooroopilly is nearly finished though. 2 years is too long for 1 project lol im never coming back here again once its finished
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
