Mugabetown - Whoretownin' At It's Worst.
$450 and a broken snes controller?
Got any fish tanks? Sounds good bud. I'm at mum n dads this weekend so I'll pick it up. Could meet you somewhere on the weekend if you can?
Not back in Brisbane for 14 days and country unfortunately, just got to site.
The engine has a R34 sized oil filter on it, would that be an issue or are they all pretty universal?
Not sure should be the same I would think. Not a lot changes between models
Just a 34 filter. (genuine Nissan item even!). I can always check it by holding a 145 next to a 442 in supercheap when i get back i suppose, but it should be good.
I'm assuming if the 442 fits on the 32 at the block its the same seal between each block at least so the sandwich plate should be the same
Yeah that's the same assumption i'm working under.
You still goign to be around in 2 weeks? Or over in india or something?
Nah ill still be here unfortunately lol. Indooroopilly is nearly finished though. 2 years is too long for 1 project lol im never coming back here again once its finished
