Mugabetown - Whoretownin' At It's Worst.
$450 and a broken snes controller?
Got any fish tanks? Sounds good bud. I'm at mum n dads this weekend so I'll pick it up. Could meet you somewhere on the weekend if you can?
Not back in Brisbane for 14 days and country unfortunately, just got to site.
The engine has a R34 sized oil filter on it, would that be an issue or are they all pretty universal?
Not sure should be the same I would think. Not a lot changes between models
Just a 34 filter. (genuine Nissan item even!). I can always check it by holding a 145 next to a 442 in supercheap when i get back i suppose, but it should be good.
I'm assuming if the 442 fits on the 32 at the block its the same seal between each block at least so the sandwich plate should be the same
Yeah that's the same assumption i'm working under.
You still goign to be around in 2 weeks? Or over in india or something?
Nah ill still be here unfortunately lol. Indooroopilly is nearly finished though. 2 years is too long for 1 project lol im never coming back here again once its finished
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
