Mugabetown - Whoretownin' At It's Worst.
Ants stop being a stinky french man and confirm your spot for the QR track day.
http://www.skylinesaustralia.com/forums/topic/441485-sau-vs-qeo-qr-sprint-day-07-06-14/
I thought spots were taken already?
I want to wait a little Grego
Sprints would be awesome but would be a huge step for me and I don't want to jeopardise the car nor anybody else's car because lack / no racing experience
Plus I need to by helmet and whatever else
Baby steps first mate
I thought spots were taken already?I want to wait a little Grego Sprints would be awesome but would be a huge step for me and I don't want to jeopardise the car nor anybody else's car because lack / no racing experience Plus I need to by helmet and whatever else Baby steps first mate
Sounds like a poor excuse to me :P $100 motorbike helmet
I like it with the wing. And if you take it off people will accuse you of having a GTR badge on a GTSt... happens to me all the time!
I agree Andy.
I'm currently repairing / detailing the rear wing.
Then I think I need to go and buy a helmet
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
