Mugabetown - Whoretownin' At It's Worst.
It's pretty simple. I don't feel ready.
If I don't feel ready it's because I'm not ready.
I want to build my confidence slowly and safely.
Not jeopardise everything in one hit because being pushed into something I am not ready for.
I can't be anymore clearer than that and will not be participating to this track day in June.
I will however be happy to spectate to see how it all unfolds
Give me time guys that is all
Fair enough Ants, happy laps first then?
Need to start thinking about a new turbo and not sure which route to take, thinking highflow or a bolt on. I want something that can make about 250 kw and decent response, anyone have any suggestions?
have a look at those precision turbos Mike.
They seem to spool up damn fast and will easily make 250+kw
Having said that I prefer bolt in applications
Yeah I'm after something bolt on.
6266's are 500+hp turbos though Tony. They spool quick... For their size. But it wouldn't be good to be making only 350hp with it. Not to mention it doesn't come on a t3 flange, so you'd need a new manifold.
I think Tony was taking the piss lol
I guess Hypergear is the easy bolt on option. Personally Id look at a 3071.
I haven't read much about Precision turbos and how they fair at the 250kw level. No doubt they make a good charger for the goal i just havent seen results for them
Grab a r34 turbo and get it highflowed at CGC, MTQ or hypergear. I had a friend that made a lazy 270rwkw and it still looked stock. Pretty inexpensive too.
Yes. Yes I was. :-D would be fun to see the silver broad minded person actually turn her wheels. :-P
Realistically for that power though, buying a high flowed turbo is probably your best bet. Cost is kept down and life is good.
^^ This, Highflow seems to get the best results these days whilst keeping it low mounted on the stock manifold and internally gated
This is what I'm leaning towards ATM, just need the 34 turbo.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
