Mugabetown - Whoretownin' At It's Worst.
Noel just got 680 hp out of his car today. After crapping his precision turbo afar not making the desired numbers with it he Changed to a MTA 900 and just pissed power. Pretty interesting!
Thought precision were supposed to be ok...
from a reliability point of view no doubt, but the power production part was the most interesting, they had to push hell out of it to nudge 600hp.
what version precision turbo was it Bunts?
64/66
Scott made 588 no problems (not on EFI dyno. Will be interested to see what scotts does make on said dyno)...
Definitely think there was something not right about the 6466 Noel got unfortunately. It struggled to make over 600hp then finally seized up on the dyno. Time will tell what i can get out of mine
Simon32 made over 700hp atw using a Precision 6262 Turbo on a standard RB26 using a standard GTR box.
Just sayin
Noel's turbo musta been le f**ked
I've not driven a700hp car but I do know the jump from 450 to 512 I thought was quite a bit then again from 512 to 588.. But it's hard to make an informed call till I've been there really
Then again all setups are different. 700hp in some cars I would be a total different feeling to 700 in another setup
700hp on a track car is doable but you want to make damn sure reliability and suspension and transmission is also up to par to cope with that power.
Is Noel's car a GTR?
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
