Mugabetown - Whoretownin' At It's Worst.
Morning all.
So...last nights drive was eventfull...
The bad,
1. Zeke's mate was supposed to be coming along in his Civic...he didn't tell us there was 10 other P platers with him as well...
2. My car started to smell like burning oil very badly. This was because the oil filler cap came off, either because I didn't put it on or because I put it on loose, and sprayed oil all over the engine bay.
3. While checking I had enough oil to drive the car safely I picked up a stick I the rear guard.
4. At the end of the run I put my thong on and didn't see the bull ant that was hiding at the end. From then on I had some very painful toes.
5. Car was still smelling of burning oil.
6. Picked up another, larger, stick with my rear bumper.
7. Cleaned up the easter bunny/hare at about 80 km/h. Sorry kids, no easter next year.
The good,
1. No one broke anything.
2. Pete blows awesome flames like Zeke.
3. Awesome drive with no unwanted attention.
4. Happened to meet up with Carl and a few of the EVO guys for a nice chat.
5. 1 less rabbit/hare in Queensland.
As long as all the cars stay shiny side up they are good night's despite all the random happenings! The random stuff is one of the main parts that makes it fun and interesting.
We were all fine, just heard from Carl that one of the EVO's kissed a guard rail with the rear quarter on the way down. Car was mostly alright other than a wrecked panel.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
