Mugabetown - Whoretownin' At It's Worst.
ok lets try this...
World's Best Single Malt Whisky 2014 Sullivans Cove French Oak Cask ABV: 47.50%
Tunnock’s Caramel wafers. With a touch of smoke. Excellent balance. Ed Bates
Toasted almonds, grated nutmeg and some fruit toast on the nose. Burnt almonds, autumn fruits stewed with golden raisins. Light, peppery and intriguing. Seáneen Sullivan
Keeping it simple in a very good way. Honey, vanilla and haystacks. All combine with apples and caramel. Jason Thomson
Campfire smoke that enriches the malt and wood. A match made in heaven with a smooth buttery feel. Joseph Cassidy
Great balance, lovely spices come through with time. Jamie Milne
Congrats to the little Hobart distillery
well if you are good at it why not get paid for it?
Shit is a booming business
Timmy sells the means to deal with shit properly, that's almost like selling it.
Yes, my job is the total shit, dealing with everyone's shit, and they pay me shitloads.....
...just hope the shit doesn't hit the fan with the latest poo pumping upgrade otherwise I may smell like shit....literally....
so shit does indeed pay after all
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
