Mugabetown - Whoretownin' At It's Worst.
ok lets try this...
World's Best Single Malt Whisky 2014 Sullivans Cove French Oak Cask ABV: 47.50%
Tunnock’s Caramel wafers. With a touch of smoke. Excellent balance. Ed Bates
Toasted almonds, grated nutmeg and some fruit toast on the nose. Burnt almonds, autumn fruits stewed with golden raisins. Light, peppery and intriguing. Seáneen Sullivan
Keeping it simple in a very good way. Honey, vanilla and haystacks. All combine with apples and caramel. Jason Thomson
Campfire smoke that enriches the malt and wood. A match made in heaven with a smooth buttery feel. Joseph Cassidy
Great balance, lovely spices come through with time. Jamie Milne
Congrats to the little Hobart distillery
well if you are good at it why not get paid for it?
Shit is a booming business
Timmy sells the means to deal with shit properly, that's almost like selling it.
Yes, my job is the total shit, dealing with everyone's shit, and they pay me shitloads.....
...just hope the shit doesn't hit the fan with the latest poo pumping upgrade otherwise I may smell like shit....literally....
so shit does indeed pay after all
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
