Mugabetown - Whoretownin' At It's Worst.
lol....Curent plan is to have the bug sorted for the SAU drag day.
Next expense is Dual carbs for the bug.....2 Dual throat 44mm webbers. should be enough for 2 litres :devil:
E85 da bug Bodo
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
