Mugabetown - Whoretownin' At It's Worst.
Does remind me tho, I really need to fit an oil filter relocation kit to my car, it's too easy for someone to just reach under the car and steal...
I need to do this next happy laps...
  • Like 1
Aww yeah. Legit one too. Needs a set of wheels and it has a few issues around the place. but has a lot of goodies
Trust sump extension
R33 GTR crank
HKS oil pump
ACL race bearings
ARP main & head studs
Eagle H-beam forged conrods
CP forged pistions 86.5mm
Ross metal jacket harmonic balancer
Tomei metal head gasket (oil restrictor fitted)
Tomei adjustable cam gears
Gates timing belt
Splitfire coilpacks
Nismo adjustable fuel pressure regulator
Nismo high flow fuel pump
Nismo low temp thermostat
Apexi power FC version 8.04a with hand controller
Garret GT2860R -7 turbos
HKS extension kit
HKS oil cooler & filter relocation kit
K&N reusable panel filter
Custom stainless exhaust 3" front pipes into 2.5"
DBA 4000 series rotors
EBC greenstuff pads up front, bendix ultimate rear
HSD HR coilovers
Billet aluminium rear subframe bushes
Adjustable rear upper camber arms
Front & rear strut braces
Bridgestone potenza RE002 on stock rims (90% tread)
Nismo super coppermix twin plate clutch
Engine rebuilt at 137694km - March 2010
Cylinder head replaced (brand new) at 181085km - November 2013
Current km's 183182km
Tuned on 16 psi at the moment making 342hp. Very naice
R33 GTR crank
HKS oil pump
ACL race bearings
Gates timing belt
Splitfire coilpacks
HKS extension kit
HSD HR coilovers
sounds good. When u buy?
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
