Mugabetown - Whoretownin' At It's Worst.
Does remind me tho, I really need to fit an oil filter relocation kit to my car, it's too easy for someone to just reach under the car and steal...
I need to do this next happy laps...
  • Like 1
Aww yeah. Legit one too. Needs a set of wheels and it has a few issues around the place. but has a lot of goodies
Trust sump extension
R33 GTR crank
HKS oil pump
ACL race bearings
ARP main & head studs
Eagle H-beam forged conrods
CP forged pistions 86.5mm
Ross metal jacket harmonic balancer
Tomei metal head gasket (oil restrictor fitted)
Tomei adjustable cam gears
Gates timing belt
Splitfire coilpacks
Nismo adjustable fuel pressure regulator
Nismo high flow fuel pump
Nismo low temp thermostat
Apexi power FC version 8.04a with hand controller
Garret GT2860R -7 turbos
HKS extension kit
HKS oil cooler & filter relocation kit
K&N reusable panel filter
Custom stainless exhaust 3" front pipes into 2.5"
DBA 4000 series rotors
EBC greenstuff pads up front, bendix ultimate rear
HSD HR coilovers
Billet aluminium rear subframe bushes
Adjustable rear upper camber arms
Front & rear strut braces
Bridgestone potenza RE002 on stock rims (90% tread)
Nismo super coppermix twin plate clutch
Engine rebuilt at 137694km - March 2010
Cylinder head replaced (brand new) at 181085km - November 2013
Current km's 183182km
Tuned on 16 psi at the moment making 342hp. Very naice
R33 GTR crank
HKS oil pump
ACL race bearings
Gates timing belt
Splitfire coilpacks
HKS extension kit
HSD HR coilovers
sounds good. When u buy?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
