Mugabetown - Whoretownin' At It's Worst.
Anyone have a contact for cheap SuperPro bushes?
Fulcrum with club discount. Just don't get them to install them :P
Andy.... I'll take em!!!
Shit bloke :(
Now, probably wasting my time, but I have these lying around (tyres not included, unless you want to pay a lot extra)
Do you like roller blades? (narrow is good for skidz..., ask anyone who spent too much on an underpowered 86) :D
Have some 17x7" 45mm offset wheels with 4/5 stud pattern
Enkei 'Orsh Varents'
Hmm... I actually don't mind the look of those for track wheels. But I would have to run massive spacers and run skinny-a*se tires on them :(. How much are you chasing for them, no tires?
Edit: also, are fagna's 4/5x114.3 stud pattern?
Anyone have access to a paint booth?
Or a shed/something that can be used as a paint booth?
by some plastic drop sheets from Bunnings for like $1 each convert your garage into like a spraybooth.
wait......
wait.......
pls tell me you have a garage right?
How many f**ks do you give about the quality of the job? I assume this is to paint the pinny?
You can spray it in my old mans paddock if you want. He even has the compressor and hoses.
I do but not able to turn it into a spray booth
I give zero f*cks, but not sure if old mate I have lined up to do it will want to do it in a paddock... will check though.
He also has a spray gun you can probably borrow to do it yourself if you want. You'll just have to clean it afterwards.
Cara's brother put a propper booth in his shed.
It is an epic shed.
Can I use it in exchange for cash/beer/reacharounds?
I can't paint to save my life
They're overweight Evo's, so yes.
So, an hour and a half before i have to leave and i've yet to pack... enough time to do O2 sensor or leave it until i return...
While photographing my spare parts for selling them I noticed this. This may be a problem.
its a cheap fix. Whoever you sell them injectors to should be smart enough to get them cleaned and flowed tested of which they will also get the caps replaced. Just sell them as they are Pete
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
