Mugabetown - Whoretownin' At It's Worst.
Anyone have a contact for cheap SuperPro bushes?
Fulcrum with club discount. Just don't get them to install them :P
Andy.... I'll take em!!!
Shit bloke :(
Now, probably wasting my time, but I have these lying around (tyres not included, unless you want to pay a lot extra)
Do you like roller blades? (narrow is good for skidz..., ask anyone who spent too much on an underpowered 86) :D
Have some 17x7" 45mm offset wheels with 4/5 stud pattern
Enkei 'Orsh Varents'
Hmm... I actually don't mind the look of those for track wheels. But I would have to run massive spacers and run skinny-a*se tires on them :(. How much are you chasing for them, no tires?
Edit: also, are fagna's 4/5x114.3 stud pattern?
Anyone have access to a paint booth?
Or a shed/something that can be used as a paint booth?
by some plastic drop sheets from Bunnings for like $1 each convert your garage into like a spraybooth.
wait......
wait.......
pls tell me you have a garage right?
How many f**ks do you give about the quality of the job? I assume this is to paint the pinny?
You can spray it in my old mans paddock if you want. He even has the compressor and hoses.
I do but not able to turn it into a spray booth
I give zero f*cks, but not sure if old mate I have lined up to do it will want to do it in a paddock... will check though.
He also has a spray gun you can probably borrow to do it yourself if you want. You'll just have to clean it afterwards.
Cara's brother put a propper booth in his shed.
It is an epic shed.
Can I use it in exchange for cash/beer/reacharounds?
I can't paint to save my life
They're overweight Evo's, so yes.
So, an hour and a half before i have to leave and i've yet to pack... enough time to do O2 sensor or leave it until i return...
While photographing my spare parts for selling them I noticed this. This may be a problem.
its a cheap fix. Whoever you sell them injectors to should be smart enough to get them cleaned and flowed tested of which they will also get the caps replaced. Just sell them as they are Pete
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
