Mugabetown - Whoretownin' At It's Worst.
I don't even watch the game/follow the game/give a shit but I contributed... I was more interested in a sleep rather than Origin because soccer was on at 2am, which sadly we lost... Although it was a good game! Can't say I was surprised but was good to see how well they played! Maybe 2018 we might go better...
Does this mean we are out of the cup? I don't really follow soccer haha
They still have one game to play but yeah they are out. They played well against stronger teams. Will be interesting how their match against spain goes especially since Cahill is out for the match.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
