Mugabetown - Whoretownin' At It's Worst.
How I wish I could have that sort of money to pour into a car :(
TBH Matty they are an insane waste of cash. That motor and fuel system on that car was circa 55k. best way to do it...save up for a house deposit and factor a really nice gtr that someone has already built up into the loan price.
this ^ man knows
Have I forgotten a public holiday today or something?
Got to work in 35min
Car park all but empty
Floor all but empty
...have I missed the apocalypse??
My works dead aswell very strange for a Friday
Fellows - it's the start of school holiday as term 2 finished for most (private) schools yesterday and think parents have also taken time off
Traffic was a breeze for me this morning compared to most other days
So they have released the inmates...apocalyptic
I checked on that Ants but shcool holidays for state schools at least don't start until after next week.
I didn't realise private schools were a week and a day earlier :S. That's bizzare. Oh well, hopefully it means 3 weeks of good traffic :)
Yup. Private schools have more time off than public schools - so you pay an arm and a leg for your child to go to private school but they don't stay in school as much as public schoolers do - go figure :blink:
Floor all but empty
Maaan I wish, not that I ever hit traffic but business as usual here despite wishing it was already Saturday!
My solution to this is not have kids to have to put through private school... I went to a VERY public school and I turned out surprisingly not as bad as I could have!
My mum also said her work is unusually dead today, only she lives in Canberra... Pretty sure there is something the rest of us have missed...
I always thought the same thing but I've learnt being in any kind of professional type job the private school kiddies have a major advantage based on who they went to school with and who's parents they know lol.
Unfortunate but true, if I ever have kids they'd end up in a private school.
  • Like 1
I can vouch for ^ this
It was my private schooling that made me obtain my current job - not just qualifactions or experience counted
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
