Mugabetown - Whoretownin' At It's Worst.
Cuz you hate me *runs off crying*
why is it that I make grown men cry???
I think I should request Kleenex to develop man tissues for you's all or maybe standard girly tissues will suffice
Brisbane has no business being this cold.
Also, f*ck public transport
Yes, this morning sucks majorly on the weather scale... I wore pants under pants today it's that cold!!!
Also, your suit had a nice ride in the warm car, not public transport :P
Missed my bus this morning!
That sucks a fat one, did you have to wait forever out in the cold? If so that sucks even worse!
I would cry if i had to drive that thing
Bwahahahahahaha ^This... Yes...
you wut?
Yup, layering up!!! That and epic leg day yesterday 120kg leg press, was an awesome session but wanted to die lol, keeping my legs warm, toasty and working on not getting DOMS that badly I cannot walk... Again...
Mel walks like John Wayne after after long and epic journey through the grand canyon
Was distractingly cold on the moto this morning. That's about 2 levels colder than uncomfortably cold.
stop being a panzie Mike and give me the low down on the Zed - is it fixed yet?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
