Mugabetown - Whoretownin' At It's Worst.
Also, hopefully got my zed sorted. Looks like it was possibly a corrupt table in the ecu. Wiped the tune and started again and it seems to be ok.
Needs some more kms to be sure, then a full tune.
Ecu running Windows ME?
And cause mine was a type s lucky me got Hicas on my NA :dry:
Yeah, lucky hahaha
hicas is f**king shit. Don't realise how shit it is until you delete it
Edited by MagicMikeZ32
Soon mine will be gone, yippee.... Martin asked me if it pisses me off, after almost 8 years of having my car I figure I am just used to it. I didn't drive Zanes enough before he got rid of it to notice the difference too much.
You notice it when it suddenly activates for the first time in over 2 years under brakes into a tight corner. If it is broke fully broke don't fix it?
oooh I know that feeling. Almost hugged a concrete barrier when mine decided to say hello
Failed safety cert =/
Caster arms and drivers seat
Someone sell me parts
I'm pulling out my factory castor arms this weekend and I have a manky/slightly torn 33 drivers seat. You can borrow both but I want my castor arms back.
such a sweet mouse aint he?
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
