Mugabetown - Whoretownin' At It's Worst.
Yeah, maybe I'll just always leave my car parked in the garage, then nothing can happen to it
:P
Seems to be working so far ;)
I use my car every week - just saying
I use mine daily.... Just saying... :P And it only breaks when I let apprentices touch it... :whistling:
I think this would have scared the crap out of me... I already thought I had to sleep with ALL the toys on the bed so they didn't feel left out let along if they actually looked like they did shit during the night... These kids will either have killer imaginations or be petrified of their toys...
http://www.b105.com.au/scoopla/trending-now/blog/2014/7/what-these-parents-do-while-their-children-sleep-is-beyond-brilliant/
cAndy! The only place I seem to be able to get an x181 is online. Are they that good that I can take the risk without trying one out?
Gimme a sec. There may be a current equivalent. The x181 is from the summer before last
Il be there on Sunday mate
Does happy laps technically count? It is taking to the track... But not proper taking it to the track... I would do happy Laps but not a proper track day, at least not in my car until she has some work done...
If you are prepared to accept the consequences of track days - then by all means
Happy laps also doesn't count :P
your words sMartie 'come out to the track ya fairy!'
Happy Laps is not just out to the track but on track!
Didn't have any issues with it, until it became difficult to buy.
I went to superlap a few years ago and one of the royal purple promo girls scarred me for life, it was horrible to see... So, so, horrible!!! Should not have worn that outfit and to make matters worse, should not have gone commando in that outfit! I pointed it out to the boys to share the burden and I think they were also scarred for life... The other one on the other hand could have sold it to me if it wasn't for her oompa looma sidekick... That right there is what I am reminded of every time I see royal purple...
Did you just turn the topic onto cricket bats?
It let me down in major ways on several occasions, Royal purple on the other hand never has. The year I went, i think 2012? One of the royal purple girls was amazing, my god the things the things I would be willing to do with her! lol
OK apparently the x181 500s is available at Greg Chappell Albion. the 500 or 700 range is about what you should be going for in Grey Nicks. The Powerbow gen X has a very similar look to it and would be a good substitute, the matrix is pretty similar too but looks a little less bottom heavy.
If you are feeling strong check out the Colossus, it reads heavy but the pick up is surprisingly good
I was at GC Albion yesterday, they only had the x181 in small mens and below sizes.
I might check out the Powerbow gen X for weights then order the x181 :)
It let me down in major ways on several occasions, Royal purple on the other hand never has. The year I went, i think 2012? One of the royal purple girls was amazing, my rajab the things the things I would be willing to do with her! lol
Hahaha yeah It was 2010 I think we went, maybe 2011! One was smoking hot the other was horrible, she bought the team down :sick:
My car isn't even close to set up enough to do a "proper" track day, maybe after I get some suspension work done I might, at least then it will handle nicely and well... Less like a boat :) Happy laps on the other hand will be done on Sunday in her... I would take Zane's car out to a proper track day but he isn't happy with the setup at the moment so more than likely wouldn't let me :(
If happy laps counts then Martin is doing a track day on Sunday :P hahaha
A reliable source tells me the X181 and the Powerbow gen X are in fact the same shape. So a long sweet spot starting low and heading up to traditional centre. They are however scalloped to make them a little lighter, meaning if you hit off center you lose some power. The Matrix has a similar length middle but is not scalloped and therefore a little heavier but is more forgiving if you get one off center. I would give both a go, if you can live with the extra weight on the matrix it may be the go, if anything I wish my bat was less scalloped.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
