Mugabetown - Whoretownin' At It's Worst.
A bit of playing around and I am used to it now... One of the PCs was upgraded from XP, so glad that old one wasn't mine!
XP? man that's old.......although I really liked XP compared to Win 7
Now I'm on 8.1 and like it but it always takes some time to adjust
ah last day of training / certification courses today ... these things are such a waste of time ... zzzzzzz
I drew a picture yesterday.
Today I get to patch 2 cat 6 cables.
#@Hardwork
a skilled kiwi???
Imposibru!
:P
Yeah the old accounts PC was on XP! It was painful, if Zane saw me use an old PC with XP and dialup internet he would run for sure! :P
Aaaand Morning all :wave:
Slow day is slow but not slow at the same time... Busy but dragging... My desk looks like a bomb exploded and it's really frustrating me but I can't put any of it anywhere else yet :(
Teins have arrived
Inb4 queries about Sydneykid bilstien package - is on hold due to other financial commitments and current coilovers are well and truly f**ked
Zane has Tein superstreets, he hates them :yes:
they are not super streets Mel.
In fact I don't believe the Teins I have sourced are even available in Australia FTM and most suspension workshops are still selling them discontinued / shitty SS.
In fact I d'ont believe the Teins I have sourced are even available in Australia FTM and most suspension workshops are still selling them discontinued / shitty SS.
I was just sayin :)
howdy peeeps
how is everyone? i have been off the radar for a long time now for various reasons. hope to get back to normal soon. have a tumor in my skull that needs to be drilled out.
ps. anyone know much about the 300ZX Tommy Karia Edition?
howdy peeeps
Wow the Benno lives.
holy shit a tumor sorry to hear about that.
All I can say is best of luck for the op and that you get back to your good ol self asap
howdy peeeps
:O I was just thinking about you the other day, long time no see! Hope the tumour drilling goes well!
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
