Mugabetown - Whoretownin' At It's Worst.
Same concept as kids eating dirt. Grows the immune system.
That's my story and I am sticking with it. I have been sick once in about 6-7 years. And that was last week. 1 day off work (not because I couldn't get out of bed, because I could justify a sickie) :)
yet you still managed to work on your z on that day
Couldn't possibly warrant a sick day :P
McFly saw me last time I was sick, he can vouch for the fact I was sick... I looked like shit, sounded like shit and felt like shit... I needed the few days I took off... Should have taken the day off in between also but I didn't and instead went home early and felt even worse! I don't take time off when I am sick unless I am proper sick because getting behind at work shits me, even annual leave I try to have everything done before I go for the time I am away so it's all up to date when I get back...
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
