Mugabetown - Whoretownin' At It's Worst.
Almost escaped home...but now have to go to the navy boat that is on fire and stand around for hours, Le sigh
In the navy........... well I just hope that no initiations take place all the whilst you are there
I don't think there are any navy folk there. Just ship yard people that let a 53 million dollar vessel go up in smoke!
Any of you guys used Uber for a taxi service? I'm going through the process to become a driver for some extra cash. Perks of having a 4 door car. :P
Nope, don't normally need taxis and the skyline isn't exactly a prime candidate to pick up randoms in.
I am convinced uber will lead to all time high levels of sex pestery
Haha... well Mike, you need a 4 door car. And Andy, you have to go through very strict screening. So far it's been more thorough than getting a taxi driver licence. It's all been very professional so far. More like chauffeur or limousine service than a taxi.
I doubt there's more sleazes than Yellow Cabs! :P
Other thing is people aren't randoms. They have to have an account with a credit card or paypal account linked, so you never get a skipped fare, and if they make a mess you can give them a bad review and charge cleaning fees. Then they get a bad record so other drivers will avoid them, and you let head office sort out your imbursement for cleaning.
Also means car is tax deductible. :D
Edited by Simink
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
