Mugabetown - Whoretownin' At It's Worst.
I have had a similar week Mel. Forgot my go card and work keys on Monday, forgot my wallet Tuesday. Luckily I have today off to reset a shite week!
My day off is Friday because we work all over the place and the other wanted a long weekend which I don't get anyway, I haven't had a good few days although didn't totally suck at Indoor last night, I actually hit some and left the ones I didn't need to hit :D Had a higher score than Martin temporarily, until I got bowled twice and ended up with the same amount of runs haha... I didn't realise in indoor as long as I moved the bat to look like I tried to get the ball I could use my body to block the stumps lol
Bonjour Mel!
We kinda needed one quickly as I was getting sick of driving my parents ute
I will give the 6 an Antz special detail and she will look incredible
Want to give mine a special detail? She needs more than that tho :P
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
