Mugabetown - Whoretownin' At It's Worst.
I'm glad I don't work close to there or I would get so fat!
I've enjoyed the last two years so I'll keep going :) I want to go to the German club Oktoberfest also!
The German Club Oktoberfest is pretty good... But nothing compares to St Patties at the Irish Club!
  • Like 1
Haha I wouldn't mind going next year, an engineer that does a lot of the plans for people that get our houses at work is Irish and I got a whole bunch of out of focus videos and photos from him this year!
We go every year, will let you know when we go!
  • Like 1
Wow you guys and gals talk alot!
with more and more cars losing thier transfer case every year I dont see the pathfinder getting one back, though apparently there will be a wagon based on the new Navara, which is pretty much what the old pathfinder was.
There is already a new Pathfinder.....not sure how it will translate to a ute thought
Yeah its going to retain a proper 4x4 system
lol
Nice. Electronic transfer case I guess though?
Theres your problem......Navara is a useless off roader...no need for a transfer case anyways. if you want tough and off road, buy a GQ racing patrol.
Nope, tomorrow night. Saturday night is LAN party time.
LAN?? where and whatcha playing?
I just want stines and german pretzels.
all of this!!
Looking forward to this, never been the the october fest in brissy.
The pathfinder will stay as is. The Navara will be updated and there will be a wagon called something else based off of the new Navara.
Dont you need a transfer case for 4x4?
I would take the shortcomings of a navara off road over the short comings of a GQ on road. We have one at the farm that we have owned since new. It was a heinous piece of sh!t in the road then and it hasn't gotten any better with age!
Edited by Bunta
  • Like 1
Y you no work Mel?
more importantly y you shop when not working :P
We were open public holiday so I'm off today. But I work at my other job tonight.
Haha because I'm fabric shopping so need to touch it and stuff...
Haha Zane saw the pretty lace and said he wishes he had the money to get it for me! Even he saw it and went wow and saw the look on my face, as soon as she picked it up I knew exactly what it was!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
