Mugabetown - Whoretownin' At It's Worst.
You know why they call it off roading......once you do it, your car is off the road (especially if you own a hilux, they love having naps on their side)
2.5 hours mo fo's!!! stupid rain.........
That's because a lot of dumb asses go looking for trouble. In 11 years of driving off road for work I have never had an issue, even in hiluxes! Edited by Bunta
How are we all
Mike I had some of this last nite
Was epically disappointed
I'm hoping it was due to either my cold not allowing my taste buds to fully work or it's a dud
Just the standard 15yo? Not had that variety before.
yes. Standard 15yo but it's the solera reserve which has had some really good reviews and awards
It's 14yo brother is sooooo much better
It was all watered down
I'm thinking it was a bad batch
Should just open the Snow Phoenix to make up for it ;)
I did, going for a nice price now. But I'm still glad I had the opportunity to drink some.
just can't justify the price - if it were $200 bucks less I would have snapped it already
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
