Mugabetown - Whoretownin' At It's Worst.
You know why they call it off roading......once you do it, your car is off the road (especially if you own a hilux, they love having naps on their side)
2.5 hours mo fo's!!! stupid rain.........
That's because a lot of dumb asses go looking for trouble. In 11 years of driving off road for work I have never had an issue, even in hiluxes! Edited by Bunta
How are we all
Mike I had some of this last nite
Was epically disappointed
I'm hoping it was due to either my cold not allowing my taste buds to fully work or it's a dud
Just the standard 15yo? Not had that variety before.
yes. Standard 15yo but it's the solera reserve which has had some really good reviews and awards
It's 14yo brother is sooooo much better
It was all watered down
I'm thinking it was a bad batch
Should just open the Snow Phoenix to make up for it ;)
I did, going for a nice price now. But I'm still glad I had the opportunity to drink some.
just can't justify the price - if it were $200 bucks less I would have snapped it already
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
