Mugabetown - Whoretownin' At It's Worst.
What ecu are you using Pete? Nistune?
How will narrowband O2's help with e85?
Better off removing closed loop IMO and tuning for a targetted afr at cruise ;)
I dunno, there's a measurement of something then magic happens in the ECU and then car runs better?
I guess i need to do research
narrow band sensors have a kind of "S" voltage curve though Pete. So the're only really good at knowing if it is 'too rich' 'too lean' or 'good' based on good being 14.7:1. If good for e85 is a different ratio, they're not going to be very useful.
Edit: Just did some quick research, e85 stoich is closer to 9:1. narrowband o2 sensors going to be quite useless.
lawl. Nistune is more than capable of handling 99% of street car requirements, regardless of the holy gtr or not ;)
can it eflex?.......................yerrrrrrr I didnt think so.
Well actually... Yes, yes it can ;)
https://www.conceptzperformance.com/Cart/description.php?II=16316
http://forum.nistune.com/viewtopic.php?f=12&t=2874&hilit=flex+fuel
Edited by MagicMikeZ32
That's awesome, now if it could take different trigger inputs and map sensors they would be in business!
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
