Mugabetown - Whoretownin' At It's Worst.
Check that you didn't bump loose the fuse in the engine bay, you were messing around in that area yesterday after all.
I actually pulled it out after I noticed the 4wd light was. same problem occurs after I put the fuse back in.
turn engine on everything ok, then a few seconds later the 4wd light comes on.
will get it fixed this week if time permits it
Lucky my mate had spares. Box is back together but still down the Goldie. Have to wait for some new parts to arrive before it goes back together anyway.
Aparantly billet options are available, but we will see how it holds up again first
standard box Mike?
Usually only throws codes if propper f**ked
allegedly you can adjust the TPS if to the required voltage.
so will give it a crack.
proly will just get a new TPS anyways from Kudos as its only $79
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
    • Piggaz had one and broke it at 470kw
    • I'm going to assume they flipped it, as the timing setup in the AEM is catastrophically wrong. Once it is fixed, they'll likely need to swap it back to normal.
