Mugabetown - Whoretownin' At It's Worst.
Check that you didn't bump loose the fuse in the engine bay, you were messing around in that area yesterday after all.
I actually pulled it out after I noticed the 4wd light was. same problem occurs after I put the fuse back in.
turn engine on everything ok, then a few seconds later the 4wd light comes on.
will get it fixed this week if time permits it
Lucky my mate had spares. Box is back together but still down the Goldie. Have to wait for some new parts to arrive before it goes back together anyway.
Aparantly billet options are available, but we will see how it holds up again first
standard box Mike?
Usually only throws codes if propper f**ked
allegedly you can adjust the TPS if to the required voltage.
so will give it a crack.
proly will just get a new TPS anyways from Kudos as its only $79
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
