Mugabetown - Whoretownin' At It's Worst.
Fly to Columbia, swallow a heap of condoms, fly home, sell contents of said condoms, profit.
You would need to quite specific about the contents of the condoms though. That plan sounds like you are hoping there is a market for stale Colombian jizz
It's up to Mike to figure out what to put in them. I'm not doing all the planing for him.
So I changed them coilovers today
What job but I did it
Took her for a quick spin and what difference
Still not quiet right in the rear and will adjust but it's a completely different feel a much better one
Still need to install the sway bars and links
  • Like 1
Looks good Ants, track day soon?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
